Rinehart and no Cat
Backpressure is a term that might get you shot around here
Yes, the Rineharts are best performing when used with a tuneable insert like the Fuel Moto 6" insert.
It works well, you can ditch the heat of the cat, and not over-scavenge as you would with a wide open pipe and no baffles.
I run them, they sound great. There are better systems out there, it just depends on what your goals are. Rineharts with a good cam do sound great
Todd1113 (05-22-2024)
do you also have the Fuel Moto inserts I mentioned?
The baffles in the slip ons are the ones that came with it. I never removed any baffles. I have the 6inch fuel moto baffles on hand, but not installed, didn't want to create too much back pressure with the rinehart baffles and the additional FM 6inch baffles too. Do I need both or will the rinehart baffles be enough?
You can reach out to FM and have them send you a tune for the inserts being installed, it will run just fine.
You have to run both. You just drill a hole in the Rinehart baffle, and bolt in the insert. You can open the FM insert tongue all the way. You will not be disappointed, especially with that cam.
appreciate all your help. Thank you
I have rinehart's on the RK and was wondering if I could ad those. Rinehart didn't understand why or what I wanted to do with there baffle for more torque
