New Heads and Cam...
Old 03-13-2024, 08:07 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 5,409 Likes on 3,617 Posts
Default New Heads and Cam...
I sent a set a heads up to Hillside and am going with stage 4.. I always felt like the bike wasn't breathing well at top end.. So we'll see what the new cylinder heads do.. 1.80" ports, 2.02 intake and 1.63" exhaust.. I'm also upgrading to a T-man 660-2 cam and I changed my intake to 1.80" to match the ports in the new heads.. I was running an HPI 1.730 runner intake.
It's been about 4,000 miles since I did my last upgrade from 103"er to a 110"er with the Woods 888 cams.. When I first did my upgrade to the Woods Tw5-6 I did measure my opinion shaft run out and had .0055" and always said I would check it over to winter.. I also upgraded to the S&S cam plate and oil pump.. I've pqut about 10,000 miles on the bike without any change at all in pinion shaft Run-out..
I know a lot of people say that the stock cranks don't hold up to power but in this last measurement I took there was no change in opinion shaft run out.. I do run my bike pretty hard that's why I build it.. My best time in the quarter mile was 11:37..
Wheelies, hole shots and just riding hard and no change in the run-out.. I'm very happy to see that.. I was contemplating an S&S crank before I took my readings but don't think I need to replace.. A very happy surprise.. Here's a video of the run out..
Just waiting for the heads and cams so I can reassemble..
The following 7 users liked this post by 98hotrodfatboy:
aharleyrider (09-10-2024), Architect (03-14-2024), Garage Queen Rescue (03-17-2024), Paintslinger16 (03-14-2024), snake_eyes (03-14-2024), tar_snake (04-02-2024), TwiZted Biker (05-23-2024) and 2 others liked this post. (Show less...)
Top Answer
05-01-2024, 08:24 PM
98hotrodfatboy
So I managed to get the bike running tonight and even went for a little ride.. Very happy with the results and will be getting it Dyno tuned very soon.. here's a short clip..
Old 03-13-2024, 08:24 PM
Moses110's Avatar
Moses110
Moses110 is offline
You're going to kick yourself for not doing this part long ago. You will be very pleased with the results.
98hotrodfatboy (03-13-2024)
Old 03-14-2024, 08:00 AM
NEWROADSTER's Avatar
NEWROADSTER
NEWROADSTER is offline
I am looking forward to the numbers when it is finished!
Old 03-14-2024, 08:41 AM
98hotrodfatboy
I do plan on Dyno tuning this one.. Hoping for 130/130.. Not that I'm chasing numbers but I am for the quarter mile I want to get into the 10's...
Rains2much (03-23-2024)
Old 03-14-2024, 09:35 AM
eighteight's Avatar
eighteight
eighteight is online now
Received 4,965 Likes on 2,857 Posts
I . I always felt like the bike wasn't breathing well at top end..
What are you using as max rpm ?
Old 03-14-2024, 10:57 AM
98hotrodfatboy
Rev limiter is set to 6200 but I normally shift at 5800..
Old 03-14-2024, 11:43 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,053 Likes on 667 Posts
This is going to be a beast!
The following 3 users liked this post by misfitJason:
98hotrodfatboy (03-14-2024), Paintslinger16 (03-14-2024), tar_snake (04-02-2024)
Old 03-14-2024, 11:45 AM
eighteight's Avatar
eighteight
Smart
Old 03-14-2024, 01:15 PM
Architect's Avatar
Architect
Architect is offline
Received 5,424 Likes on 2,765 Posts
Going fast is so damn expensive!!!!
Good luck with the results.
The following 2 users liked this post by Architect:
98hotrodfatboy (03-15-2024), Paintslinger16 (03-22-2024)
Old 03-14-2024, 02:02 PM
harpwrench's Avatar
harpwrench
harpwrench is online now
What are you going to do with exhaust?
Quick Reply: New Heads and Cam...
