Relocate license plate after tour pack removal
2019 Ultra Limited.
Looking to remove the tour pack but need to relocate the license plate.
It's a Canadian bike, so my understanding is the rear end is a bit different (or is that just road glides?). This bike has a center tail light.
Is there a bracket or something I can buy that will attach the license plate to the tail light? Don't want to drill into the fender.
Or any other suggestions for relocating license plate that doesn't involve drilling?
Thanks
Thanks
Check with a dealer for HD# 67900167 (chrome) or hd# 67900362 (black) for the HD tag mount that came in the quick disconnect "kit", if you want the tag above the fender brake light.
If you want it below the brake light, just google it and you'll see a lot of people are making those now
https://www.google.com/search?client...UTF-8&oe=UTF-8
The following 2 users liked this post by dbarbee:
Crazyasian (08-28-2023),
Goose_NC (04-16-2024)
I used CD's plate relocation bracket and their lit tag frame.... then changed the brake light lens to one without a clear tag window.
If you use that Drag Specialties lens with the tag window on the bottom, be sure to get the LED bulb (about $20) because that lens isn't made for an incandescent bulb.
RoadGlide.Australia (04-22-2024)
Parts list
Can you send me the parts list please
Can you send me the parts list for this please? I just registered so I can't send message yet apparently
https://www.customdynamics.com/motor...location-mount
then decide if you want a new cool taillight and buy this with lens of choice and bottom license plate light window option
https://www.customdynamics.com/probe...-led-taillight
or you may leave your current taillight and install the lighted plate frame
https://www.customdynamics.com/radiu...d-illumination
proper way to connect this frame is to end its harness with tyco 070 connector at necesary length to reach the fender tip connector inside the taillight (license bracket has an indent to allow the frame harness to get inside the fender)
https://www.ebay.com/itm/250914341491
Pretty easy work and you will have a very nice and clean setup.
