117 with Stage II Power cam
Greetings,
Have an LRS ST on order and am curious about the engine. Being that the 117 was only available in the CVO's, has anyone done the Stage 2 Power cam and was it worth it?
How did the power band change? Did it still have a strong low end?
Very much appreciated....
I inquired when my cvo 117 was new and found out the torque cam is not available for the 117 so I asked about the power cam. Was told that my bike may perform a little worse on bottom with the power cam over stock but would have a better top end. I ended up with a S+S 475 and was very happy:
rauchman (02-05-2022)
Greetings,
True, different pistons and what not. I was just thinking that'd be a better comparison than trying to judge how the low end will be between two bikes with a 160 lb weight difference.
The 117 has what is considered a hotter cam than the 107/114, which share the same cam, between the each other. Although, the 117 still isn't the 447, it is closer than the stock 107/114 cam. The cams for all the stock bikes are designed to be EPA compliant, which is funny that an EPA tune with the 447, when installed with the 119 and 122 kits has an approved tune...but no approved tune for the 117. With the right tune and capable tuner the 447 can be a very worthy cam. Have seen 125tq and 106hp in a 114, with the stock headpipe and a non-SE tuner, and I'd have to believe that 130-ish tq and 110-ish hp could be seen in a 117...even better with cat removed or aftermarket head pipe of choice. The point being that those that already have a 447 could have better numbers instead of the expense of changing cams and not just getting a better tune (tuner) and then only have similar numbers.
