Metra 95-HDIF-NP Opinions
Bookie (01-03-2022)
Bookie (01-04-2022)
I installed one on my 09 ultra classic BUT let me tell you I'm glad I got the unpainted one I had to do alot of trimming, opening holes bigger plus for 1 1/4 10" KST mayhem bars and replaced the 2 outer fairing studs for shorter ones to close the gaps... I wanted it to fit like the OEM fairing. I did buy new gaskets and had to drill holes in it so I can use the adjustable wind deflectors so after getting it to fit right then I painted the fairing . Guys on YT didn't tell or showed any of fitment issues but I would do it again. Good luck
Sony ax7000 installed
Bookie (01-04-2022)
That looks great!!
Bookie (01-04-2022)
bookie i had a time lining the air deflectors they rubbed the outer fairing when I close them, they wasn't even so I had to drill more holes but there covered with the air deflector brackets. I used shorts stainless steel screws with cap nuts.
Checking the fitment with old rubber trim and air deflector
Without replacing that stud there would've a gap going down the sides. I used a go through nut that i had to cut down and a short piece of threaded rod also had to cut short threaded into Outer fairing with red lock tight.
Wrapped radio for water
You can see the nuts i used for air deflectors
Bookie (01-06-2022)
great details
qclassic (01-06-2022)
