Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Rear Differential
Old 09-20-2020, 09:07 AM
evotrike's Avatar
evotrike
evotrike is offline
Default Rear Differential
Have Champion kit on my 98 Ultra. Trouble with rear end. An intermittent click/clunk noise at low speed under 20 mph. Have no idea what year, as I got nowhere with my VIN #/sticker on kit.
. Thought I'd start out by checking the grease/gear oil level . Has anyone had any experience with this rear end or seen this type? Hex head plugs (2) are on opposite sides of the case. No drain plug. I know they played around with a lot of different setups on these. Entire case rotates. Think it's a limited slip differential.
. ANY info would be helpful. Already tried trike forums. Thanks. Ken
WP50 (07-05-2024)
Old 07-05-2024, 04:43 PM
bones3's Avatar
bones3
bones3 is offline
Hello, I just came across this thread searching for the same info as you. We you ever able to find anything out on the rear end noises as I have the same noise on a trike I just purchased. Thanks a lot, hope this gets to you.
Old 07-05-2024, 04:52 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,877 Likes on 1,272 Posts
@evotrike
He's still around.
This should send him a notice
WP
bones3 (07-05-2024)
Old 07-05-2024, 04:56 PM
bones3's Avatar
bones3
bones3 is offline
Thanks for the help.
Old 07-06-2024, 06:00 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,392 Likes on 5,512 Posts
Keep search contacts at . Someone there knows the answer you just need ot find them.
https://triketalk.com/forums/champion-trike.308/
Magnut1
Shovelhead
05-04-2016 05:02 PM
iwillfixthem4u
2014-2023 Touring Models
03-11-2015 09:32 AM
shortleg
10-18-2011 09:47 AM
zoood
05-07-2009 06:39 AM
89heritagesoftail
03-04-2009 07:43 PM
Quick Reply: Rear Differential
