Finally did my breather bypass (pics included)
Old 10-08-2014 | 05:16 PM
TUCCI's Avatar
TUCCI
Default Finally did my breather bypass (pics included)
Well after taking a look inside my TB I decided I really needed to vent the breathers to atmosphere. Here's what the TB inside looked like:
There was oil caked inside my TB that needed to be sprayed down. There was no cost effective way to do a bypass and the aftermarket options left me wanting. So, I read-up, explored my options and decided to drill and tap hose barbs to my AN Big sucker.
I used a 11/32 drill bit with a 1/8-NPT-27 tap to thread my holes and install these:
Here's how it turned out:
It was long overdue and glad I finally did away with crancase BB being sucked into my TB.
Ive got the end of the hose coming down just before the cross-over to the left slip-on.
The following 11 users liked this post by TUCCI:
Bafflingbs (10-11-2022), binarym (04-09-2023), Bong (03-17-2021), BrownSanta (03-01-2017), Daniel58 (10-29-2020), Gorion (04-01-2022), Joe from So Cal (09-18-2024), marlin schwanger (01-23-2017), NiteOwl (08-05-2022), PhDr. (08-04-2022), sleighcrane (03-08-2016) and 6 others liked this post. (Show less...)
Old 10-08-2014 | 05:37 PM
crimson13's Avatar
crimson13
Nice write up , good pics.
Fingas74 (06-20-2019)
Old 10-08-2014 | 05:45 PM
Softy 103's Avatar
Softy 103
You must have excessive blow by, I would figure out the cause of that.
The following 3 users liked this post by Softy 103:
Fingas74 (06-20-2019), Joe from So Cal (09-18-2024), Satire (07-31-2022)
Old 10-08-2014 | 05:49 PM
SBates08's Avatar
SBates08
Hey TUCCI what did you use to block the drain tubes on the AN?
2010 Limited with some stuff
Old 10-08-2014 | 05:56 PM
TUCCI's Avatar
TUCCI
I used black RTV, I cut the tip off the end and stuck it in the little hole and squeezed till some came out the other side.
Old 10-08-2014 | 05:57 PM
Florida Swamp Yankee's Avatar
I wouldn't say the mess was excessive, mine looked very similar before I went with the Kury Corsair set-up. There is enough pressure to run the hoses up and over and have gravity do the rest. The Kury kit had a Y connector which installs over the top of the TB, I used braided SS hose down along the frame to just below the bottom of the drive belt.
It's been over 2 years with no problems and a clean TB!
Old 10-08-2014 | 05:58 PM
SBates08's Avatar
SBates08
Good deal. I figured that's what you did. Gonna do this to mine soon as well.
Old 10-08-2014 | 06:36 PM
Delta's Avatar
Delta
Just did a very similar mod to my CVO A/C. It is similar to the SE Ventilator A/C. Instead of venting to the ground, I vented to a crank vent breather I found on EBay for cheap money. It is almost a perfect match to the K&N air filter, and it is washable.
The following 2 users liked this post by Delta:
Campbell75 (03-15-2020), Old Patriot (10-17-2022)
Old 10-08-2014 | 07:05 PM
TUCCI's Avatar
TUCCI
is it the chrome filter in between your push-rods?
Old 10-08-2014 | 07:55 PM
UltraNutZ's Avatar
UltraNutZ
excellent work TUCCI!
Here's what a bike with just 9k on the clock looked like last week when I pulled the heads to replace them just in case you want to see what that crap does to the inners of your motor. Enough of this build up will also throw off your tune.
The following 3 users liked this post by UltraNutZ:
binarym (04-09-2023), Ronbo1 (10-29-2020), Satire (07-31-2022)
