Best carb for shovelhead?
Old 04-02-2017 | 11:08 AM
U-234's Avatar
U-234
Thanks, TwiZted, for the info on the Weber. I may just hang it on the wall in the shop as a conversation/decoration piece.
  #62
Old 04-02-2017 | 11:14 AM
TwiZted Biker's Avatar
TwiZted Biker
It's a bit of harley history that a lot know nothing about , somewhere some old school knuckle dragger would love to get his hands on it but finding his cave will be the issue
The following 2 users liked this post by TwiZted Biker:
Bumpandrun (12-20-2019), Racepres (12-19-2019)
  #63
Old 12-18-2019 | 10:36 PM
handsmshovel's Avatar
handsmshovel
6th Gear
i have an 83 shovel hi-4n ignition , ls cam and super e also,,,i just rebuilt the motor and going to clean the e carb wanted to ask what you run on the settings to turn it over , thanks in advance
  #64
Old 12-19-2019 | 11:44 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Don't quite follow your questions... What are "settings" for what..? And turning what over?
  #65
Old 12-19-2019 | 12:28 PM
handsmshovel
6th Gear
I guess that would help ...lol..I have 83 shovel w super E as well ...I wanted to know your settings if possible roughly how many turns in or out on the settings
Your fuel mix, idle and x pump. Just a reference . I know I can play with it but any short cuts or opinions are appreciated ..
Turning the motor over ...starting it from fresh rebuild
  #66
Old 12-19-2019 | 12:55 PM
98hotrodfatboy
Usually 1.5 turns on the mixture screw for starters. Fresh rebuild, rings, valve job and lifters I would crank it for 30 seconds with plugs out twice (with rest in between) just to get a little oil moving around....
  #67
Old 12-20-2019 | 08:57 AM
Racepres's Avatar
Racepres
Let me add... Tuning is done with No Accelerator Pump.... None
If needed, after all else is done... or if the User is a Throttle Jockey!!!!
Be careful cranking an old Shovel with no plugs in... a good recipe for a Stuck solenoid...
A Good Wrench already has your oil up to wherever it is required... Some wrenches???? Not so Much.
Be careful!!!
Not that I do Not have an S&S Carb or "some"... I really like the CV, but hate the Manifold adapter...so QwiksilverII for me thanks...
LOL... Just throwin some **** at the wall!!!!!
  #68
Old 12-20-2019 | 09:17 AM
98hotrodfatboy
Be careful!!!
I see you read that book too... "Brown Spots on the Wall"
by "Whoo Flung Poo”....
Racepres (12-20-2019)
  #69
Old 12-20-2019 | 09:53 AM
Racepres's Avatar
Racepres
Well...now you assume I can read???
LOL
****!!! This Internet crap kinda gives that part away a little bit huh???
Tho My first Mac... back in the '90's, could read to you... in strange voices!!! Remember that one????
Sheesh... new study in how to sidetrack a topic!!!!!!
  #70
Old 12-20-2019 | 11:26 AM
98hotrodfatboy
Just a little humor that's all.. but when it comes to carbs everyone had their preference.. they all work, just depends on the mechanic...
Quick Reply: Best carb for shovelhead?
