Can I add baffles to this exhaust system?
V_twins, I really like the first pair, SE Baloney Cut but with that mounting tab I don't see how I can use the stock mount I currently have?
Found these that look like others you recommended and should work with the current mount?
http://www.ebay.com/itm/131110032999...84.m1423.l2649
Really appreciate your taking the time to provide options!
Pretty much any OEM tapered muffler would work... the newer-the bigger!!
--- check these out ---- http://www.ebay.com/itm/Chopper-Bobb...78dae3&vxp=mtr ---
Thanks again!
What about Carburetor Jetting?
Forgot to think about the need to re-jet the carburetor after changing the mufflers. I have not taken the carb apart so I don't know what jets / bleed tubes are currently installed? Its a S&S Super E.
Any recommendations what I should purchase for a stock 80" with stock sportster/dyna (I assume similar to stock FXR?) mufflers?
Also, I read about Yost Tubes, Zippers Thunder Jet, and the Bomb Site secondary venturi main jet. Any thoughts on those?
Thanks!
Thanks!
