Scratched cylinder wall. Cylinder boring or new heads.
Old 12-05-2013 | 06:34 PM
freud's Avatar
freud
6th Gear
Default Scratched cylinder wall. Cylinder boring or new heads.
Hello
I discovered that one of the reasons why the bike is throwing smoke might be a scratched cylinder wall, if not, I just think i'ts not nice to have a scratched cylinder.
The engine is stock.
Could I try to fix this and take advantage of it gettin bigger compression pistons and just machining the cylinder a bit to make room for the bigger pistons? I've never donde that, I've usualy gone the "buy it " way, but i want to avoid spending on new pices it it can be fixed.
For those involved in previous engine modifications or restorations this may seem too obvious, but i sincerely don't know.
Any help will be apreciated.
Thanks
Old 12-05-2013 | 08:05 PM
Joe12RK's Avatar
Joe12RK
yes it's cheaper to repair than buy - you need to find a local machine shop and let them look. depending on how worn your cylinders are and how deep the scratch is you may get away with just a fresh hone and rings and re-use your pistons. you'll never know until they are measured with precision. joe
Old 12-05-2013 | 09:15 PM
freud's Avatar
freud
6th Gear
thanks joe
Old 12-06-2013 | 10:22 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Originally Posted by freud
Hello
Thanks
Have a well-equipped shop measure piston/wall fitment, and also have them take a look at valve stem/guide fitment.
At that point follow their advice and you should be able to 1), end any smoking issues, and 2), realize new power as well.
Scott
Old 12-06-2013 | 08:55 PM
TwiZted Biker's Avatar
TwiZted Biker
Anything you buy for a shovel that doesn't cost as much as the bike did needs to be checked & sized anyway , as Hills Country said find a decent shop and have it reworked is will be cheaper .
Old 12-11-2013 | 03:26 PM
neenatasnea's Avatar
neenatasnea
6th Gear
But still it is an assumption that the cylinders are scratched. You can check it out and see if that is so.
BobRR
04-08-2019 01:44 PM
hdrider98ci
03-21-2019 11:31 PM
myke99
EVO
11
02-20-2015 09:10 PM
speakerfritz
12-19-2011 06:47 PM
jdusty21
Ironhead
06-29-2007 01:31 PM
