Older frame
I have a pre 69 frame that has a hard tail welded on. I am looking to build it but not to sure about the engine. I know it should have a title but I'm not into it for the price most are asking. Is there an alternative such as a newer engine? I know the Vin is on the frame but there has to be an easier and less expensive way. Thanks
Received 3,341 Likes
Not sure about Ky but in Kali 69 and earlier are registered by motor number. Starting in 70 it was required that motor and frame numbers match; otherwise it is considered a 'Special Construction' and is basically just a mutt. States vary on whether motor or frame go with sale.
66-69 genny shovels are pricey but doable. No 'cheap' alternative and still keep it registered as a Harley
onehellofabackrest
05-29-2013 08:36 AM
