oil lamp is on, oil is flowing?
Yesterday the oil lamp when on shortly after getting started. I've got a '72 FX. Returned back home and took the cap off the oil tank. Oil was returning to the tank via the upper return hose. Got plenty of oil in the tank. The bike has been running great otherwise. Running a stock motor with an S&S oil pump. At very low rpms the light goes on, but flickers with the rpms of the motor. Yesterday the light was bright and constant. I wonder if it isn't an electrical problem or is the pressure switch bad? Any input on that would be greatly considered,
dkaat
dkaat
Smokedawg
07-02-2008 10:03 AM
