trans ????
trans ????
hey everybody, new member here. i will try to be brief but thorough as possible. Last fall i bought a 79 lowrider from a friend. I love this bike. My problem with it is that neutral is very difficult to find. I have to upshift then lightly tap the peg down to get it. works about 40% of the time. I could live with it but id rather get it right. It is a 74ci, lowered front and rear, forward controls, 4 speed bike. My friend says he had gone through everything personally or had someone look at it. Any thoughts? Hub, cable adjustment, linkage, ?? Thanks in advance for any advice . Todd
For some reason most people don't think the primary chain has anything to do with the clutch....so your friend might not have considered it. I find that most of the time, if the only problem is neutral is hard to find...the primary chain is too tight. The adjustment spec is 5/8 to 3/4 inch deflection at the tightest point in the chain when cold....nobody finds the tightest point in the chain...and they all shoot for 5/8...too loose is better than too tight...your mainshaft bearing will thank you.
the shovel clutch basket has a thing it does that was never corrected by harley, and that is when you pull the clutch lever in the clutch hub moves outward to the left, and this in turn causes the clutch discs to slightly drag and that is most times the netural issue, that cant be fixed with normal adjustments < if this is the case with yours than they make a thing called a ( ram Jet ) its plastic and it replaces the springs that do not do the job they were intended to do on some machines - what it does it stops the hub from moving and that allows the discs more room for disengagement -- hope that helps - jz
A number of products out for it but I like Dry Slide Bike aid . Hit any local jap bike place they can hook you up without the harley mark up . You should do all the cables at least once a season , more if you ride in a lot of rain or wet areas .
