FatBob front axle spacers on 21"
1980 FXEF-80. Putting back together from boxes. I'm sure I'm missing a wheel spacer.
Speedo side has plenty of space and appears proper. Opposite side is inset and when put together fork leg touches rotor. Ideas?
I have the FX Parts catalog but since my uncle had put a 21" wheel on it, my guess is he might not have used stock spacers.
Thanks,
J
Thanks,
J
Spacers
Just had the same problem last week put a 80 spoke 16" wheel with duel disk on my 79 FXS and what I finally had to do is get a bunch of 3/4 washers 3 different thickness and mix and match till I got it right and had spacers cut to the specs of the washers. The left side was barely hitting the rotor so I had space the fork tube out 10/1000. Took it for a ride and seemed fine.
