CV carb conversion- cable issue
Hey, I just got a Keihin CV Carb to replace the original butterfly carb on an '84 FXSB which has apes on it. I got the manifold adapter and all was well until I tried to hook up the throttle and idle cables. The amount of exposed wire coming out of the housings seems to be backwards. The throttle wire is too short (or housing too long) and the idle wire may be too long. Can this be remedied by cutting the housing on the throttle cable and if so, by how much? I'd rather not have to buy new cables if it can be avoided. Thanks.
Trust Al on this one,,I did the same last spring,fortunately wasnt in gear,but yes,cable kept binding up where i would cut the housing,,,had to buy cables for a newer bike,the same year bike the carb came off,but I never replace the idle,as I just could not match it up for some reason.so I run with throttle and thats it.But what a tremendous difference in smooth idling and throttle response,best thing i did to that shovel,,put on cv carb
9192daveyc
Carburetor Related
02-06-2013 05:59 PM
