81 sturgis starter removal
Hello im doing a mainshaft seal in a friends bike for him I cannot seem to figure out how that dam starter comes out? ?I've got everything else off to get the inner primary outa the way but is there a 3rd blot that holds that starter to the inner primary/ do gota gut the srter in the bike to find this mystery bolt thanks rat
Those had a 1/4" bolt that went all the way through from the inner primary to hold the stater on the inside ear you'll see the head just under the arm that pulls the bendix in and there is the rear support under the battery box . As long as you unbolt the starter you can leave it in place and pull the inner primary off otherwise it's usually drop the oil tank & battery box to get one completely out without a huge wrestling match .
JustDave71
05-26-2010 12:54 PM
