Headlight failing to light
Replaced the ignition switch month or so ago with no issues .. Now the hi-beam indicator light comes on when starting bike and at same time the headlight goes out .. Did it a few times but always came back on. Today it did it and headlight will not come on and hi-beam indicator light will not shut off. I pulled indicator light cleaned and replaced and checked and rechecked the wiring on ignition switch.Is it possible the head light burned out and the indicator light is .. well indicating that? Or is there a short hidden somewhere?
Trenton Original
04-06-2010 08:39 PM
