lukas synthetic 50wt yes or no ?
Received 3,346 Likes
I've a friend who burned up a perfectly good motor because he was convinced synthetic was the way to go on his 81 wg. Not sayin you cant run it, but he did alot of reading and research and made his decision based on what he read. What he didn't do was find one compatible to large displacement air cooled engines.
I dont personally know anything about Lucas oil but I have had no problems with HD 50 or 60 in engine, and Valvoline 80/90 in tranny. My primary is still factory so it oils off the engine oil supply (for now).
Anyway, choose carefully. It could cost alot more than an oil change!!!
my .02....
jim
my .02....
jim
I dont think it matters that much. Some would argue that, but as long as the primary chain and clutch hub bearing are gettin some kind of lube.
BTW,I dont know you or your experience with shovelheads so at risk of sounding like a ***, are you certain you have a sealed primary? They dont come that way from the factory. Because if it isn't sealed you dont add any oil to it.
Not tryin to offend here just tryin to caution!!
jim
jim
Naw put it in the trans too the old service manuals called for 50wt same the motor . Stuff will work just a higher chance for leaks on older bikes with some miles on them . Synthetics wants OUT and it will find ways fast on a shovel or pan , they will start seeping and weeping all over .
My bike does not leak I can't abide it , tried synthetics and I swear within 500 miles it was bleeding more that my old lady from everywhere . Rocker boxes , base gasket's , oil pump gaskets & at the hose clamps ect . It's what synthetics are designed to do get into the small places fast and stay there . Brand new rebuild with everything tight & new I'd say ok things have come up a lot materials wise but older worn iron she's going to weep everywhere soon and you'll be finding the little puddles after a day or 2 of sitting .
