Carbon
Old 01-28-2012 | 07:44 PM
berndog's Avatar
berndog
Default Carbon
I have my motor apart and looking for wisdom about cleanaing up valve area,the dome and top of pistons,just covered in carbon,Thanks
Old 01-29-2012 | 11:36 AM
TwiZted Biker's Avatar
TwiZted Biker
Spray on gasket remover , or paint stripper is the same thing and you have let is work for a while with some scrapping for heavy stuff . Second option is a brass wire wheel on the cordless drill jus plug the oil return holes .
Old 01-29-2012 | 01:20 PM
berndog's Avatar
berndog
I can even use this brass wire wheel on pistons and combustion chamber? and what about bead blasting or polishing after?
Old 01-29-2012 | 04:33 PM
Jackie Paper's Avatar
Jackie Paper
Narrow scraper, screw driver or whatever is handy. Just the build up, not the aluminum. Little bit of thinner on a shop towel. It's just coming back. Need not be perfect for a street bike. It's actually cooked oil since unleaded gas will only deposit a small amount and flakes off unlike years ago with leaded gas. Just my opinion. Little late for this but went thru a Z28 al head motor while back. Was leaking water in two cylinders. They were clean. All the others had 3/32 of cake on them. Not sure what it would take but revving to 3-4K and a steady fine mist in the carb use to be a fix in the 60's. I probably would not bother trying that and I sure would not do it unless I was tearing it down anyway.
Old 01-29-2012 | 04:59 PM
TwiZted Biker
Think about the violence that goes on in that combustion chamber, a cheap wire wheel isn't going to hurt believe me just blow it out real well and any micro particles are going right the exhaust in the first 1/2 second it runs .
Old 01-29-2012 | 05:04 PM
berndog's Avatar
berndog
now what about porting and polishing? seeing as I am a metal polisher by trade ,I really want to get into it,and make it shiny
Old 01-29-2012 | 05:12 PM
TwiZted Biker
You can clean them up and polish the dome area but i wouldn't do much but clean up the rough castings in the ports . A good port job they actually add material and reshape the intakes , just smooth out the exhaust side and don't go crazy around the guide boss .
rgr357
Engine Mechanical Topics
14
03-20-2015 10:30 AM
floowmatt69
05-24-2013 12:38 AM
DJY
02-18-2013 04:58 PM
iclick
10-02-2009 02:47 PM
38knuckle
Shovelhead
04-03-2008 06:20 PM
Quick Reply: Carbon
