Oil blowing out breather hose
If she was running and no work done do a cylinder leak down test and listen closely to the oil bag with the cap off and the breather hose . Make sure you it TDC on the compression stroke for each hole when test it , you hear a lot of air in the oil bag you have some busted rings or the gapes lined up seen that a number of times it will blow by pretty good . Worse case a wrist pin keeper popped on you .
jammer1
Oil Archive (no new posts)
02-14-2006 09:08 PM
