My 82 FXWG kicker kicks over way too easy,there is roughly 90lbs compression,buddy syas rings must be gone ,got lots of power no oil burning ,,any ideas why it kicks so easy,,maybe stuck valve? or??
Could be she has low compression pistons and did you do a comp test while cold and then hot and your cam ? one with over lap will be low on comp and the kicker will just push through . My old 88"shovel engine ran 135 a hole and I could push her through by hand so unless shes not running right you may not have a problem .
