Primary isolation
Old 10-25-2011 | 02:47 AM
Go Shovelhead Go's Avatar
Go Shovelhead Go
Default Primary isolation
What are the advantages of isolating the primary? Do you have to go to a wet clutch? I took apart the clutch a while after I first got the bike (82 FXRS) and there was little wear but it was partically oil soaked. Starting smoothly off the line was hard to do as the clutch would drag more as the rpms got closer. After cleaning the oil and breaking the glaze the clutch worked perfectly. Unfortunately after about 8K miles it seems the oil is getting back in and the clutch is grabbing more. Also how do the bearings inside the clutch basket get lubbed?
Old 10-25-2011 | 02:20 PM
sqdealgeorge's Avatar
sqdealgeorge
Default dry primarys
Most of my bikes are dry prims with 8mm prim belt set ups The 46 and the 52 have the old 3 finger clutch baskets like yours and the old prim chain oilers are re routed to the outside of the tin inner primarys Every other year I take the clutches apart sand the fibers and clean the steels Keeps them running great After going with these prim belts (NO BELT TENSIONERS) The orig prim chain system is obsolete in my book OK for the EVOS and up My 93 FLHS still has the orig prim chain set up (wet clutch system stock )
Big Dave
EVO
46
04-06-2015 10:11 AM
jpooch00
Classic
12-12-2008 11:06 PM
shovelheadsteve
Shovelhead
07-07-2008 02:59 PM
dope_man_21
03-08-2008 08:19 PM
hotscooter
10-31-2007 10:35 AM
Quick Reply: Primary isolation
