HD blues
Received 1,296 Likes
Carb problems seldom cause one cylinder to drop out. It's usually something with the ignition system. That said, did you check the manifold sealing when you changed the carb? Usually a leaking manifold will not simply drop a cylinder without first putting on a snorting, burping, and back-firing hissy-fit of a show.
What type ignition system? But, first things to check would be spark plugs, spark plug wires.
Stock wasted spark-type ignition system - if you can, move the plug wires to the other spark plug- leave them connected the same at the coil & just swap them at the plug; if a wire is bad your problem will move to the front cylinder.
Plugs and wires are cheap, so have you tried replacing them?
FXD_noob
11-14-2013 01:32 PM
Mickeys Customs
10-26-2007 07:35 PM
