Clutch Squeal
Clutch Squeal
Good day to all.
Running a 1975 FLH (74 inch) and for as long as I can remember I've had an irritating squeal when I take off from a standstill. Squeal is only in first, never in 2, 3 or 4. I'm running a dry clutch and a belt primary. Logic tells me it would be an issue with cable tension, I've let it out a bit and no appreciable difference. I tighten up the cable and I don't get full clutch engagement in the upper gears.
Any tips or tricks would be most appreciated.
Uh...it wouldn't happen to be a BDL "Quiet Clutch" would it?
I had one of those and I was never able to get it to stop squealing when engaging from a stop.
I talked to the folks at BDL and they sent me some "fixes" including two new clutches.
Nothing worked.
I gotta hand it to 'em at BDL. They really tried to help me with that squeal.
I went back to chain drive and installed a Barnett Scorpion clutch. I'm very pleased with this set up.
Nothing worked.
Nothing worked.
Nothing worked.
Whole thing was pain belts didn't fit too tight or too loose and the noise . I've run an open with exposed chain before on an old rat pan and it wasn't that bad . Still have the thing because I would feel guilty selling it to somebody knowing what it does .
I'm hip. Mine's sitting in a box. I don't know what to do with it. I'm using the engine pulley with an adapter I made to rotate engines. That unit has some outstanding design in it (clutch hub) but they came up short with the clutch.
tat2dancer
05-26-2017 03:22 PM
