dry primary leaking
Old 12-03-2010 | 10:22 PM
Jackie Paper's Avatar
Jackie Paper
Default could be
The problem could be the seal you see in my album 'primary chain-- picture 16. The primary is still vented thru the clutch push rod hole and back thru vent on top of transmission. With a primary belt I would have thought at least the drain plug would be removed. Oil get get in there from two places and what happens if it gets a lot of oil in there? Just my opinion since I had not delt with this type of conversion.
Old 12-03-2010 | 11:16 PM
squirlshovel's Avatar
squirlshovel
mainshaft seal does sound like the culprit . take the outer primary off and investigate .check to c if its commin from the crank seal as i have come across the same prob. and yes keep an eye on the fluids cause no u dont want those repairs
Old 12-03-2010 | 11:21 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by langwilliams
Nice thread , a little over the top on machining a new bushing but if you have the tools it's great .
A stock replacement bushing and the double seal trick will get you there no problem . maybe 1 in 20 people will have a clue about machining the spacer for an o-ring if your lucky .
Old 12-04-2010 | 10:09 PM
langwilliams's Avatar
langwilliams
I found a guy that's a machinist for NASA Glenn here an he's doing my machine work. Just got to wait 2-3 weeks for him to have time to get to it. Hope I don't forget how every thing goes back.
1340fxrt
EVO
26
12-19-2021 08:09 AM
Road Star
09-24-2016 02:15 PM
kingkingking
11-08-2009 08:36 AM
Rain
08-17-2008 06:07 PM
moblmowr
EVO
25
04-02-2008 09:44 PM
Quick Reply: dry primary leaking
