stripped starter mounting holes
I was going through my '78 shovel, just bought it and noticed that the long mounting bolts were loose, they actually just slid straight out. so I removed the "Hitachi 31507-73" starter and it appears that where they bolt into is stripped out any suggestions on how to fix?
You mean the 2 long thin bolts ( about 6" long ) on the end of the starter itself ? Or the 1/4" ones ? If it's the thin one it could have snapped off , pulled out the threads or just be misaligned and your not hitting the hole . The support bracket works loose or has been removed starter will shake apart too . Good luck
If it's bummed threads in the offset housing a heli coil kit runs around $25 those are 10-24 thread , I've turned the starter a bit and drilled & tapped new ones before if you have the tools . A housing is $65+ aftermarket last resort .
No too bad really if your handy with tools . It's tight under the oil tank but can be done . Dropping the battery box & oil bag isn't as bad it looks , gives you more room to work and you'll probably find the rubber iso mounts & oil lines need replacing anyway . The housing may be mounted to 2 studs coming out of the pri. case or one side could be a through bolt into the primary , cover comes off then .
good luck
Check the starter bolt length it should be a fat 5 7/8"+ long inside the head to end , with 7/8" of threads on the end , they do break .
good luck
Finaly got the time to remove the housing and the threads are 1/4-20, it seams that maybe they were taped to that size for the heli coils that aren't there. so maybe i should start fresh with a new housing? except that the oem number (31467-65) dosen't match up with any of the new housings that are for sale, they do look the same and the numbers are:
31465-65 Housing 1965-E79 FL
31465-79 L1979-84 FLH Prestolite
also the motor that came off of it is a Hitachi oem 317570-73 is this the right motor for one of these housing? or even the hold housing?
sorry to be such a pain!
Jim C.
Prestolite 1971-72 FX
31572-73 1973-79 FXE Hitachi
31572-79 1979-up FX Hitachi, 80-83 FLH
Jim C.
