front sprocket 1976 super glide
Old 07-21-2010 | 03:48 PM
sailfish's Avatar
sailfish
Question front sprocket 1976 super glide
Does anybody know if the threads on the nut on the front sprocket are right or left hand threads ?
Old 07-21-2010 | 06:09 PM
11sec.shovel's Avatar
11sec.shovel
Its been quite some time but i believe both engine and trans sprockets are RH.
Old 07-21-2010 | 10:27 PM
flh80's Avatar
flh80
The engine is RH, they do come off hard. Fine threads, I always put some grease on when going back on so it doesn't bind or tear up. Anti-Seize lube would be good also, oil isn't enough.
Old 07-22-2010 | 07:59 PM
sailfish's Avatar
sailfish
Smile thanks
thanks flh80 for the information
Old 07-23-2010 | 06:33 AM
skully_68's Avatar
skully_68
compensator or solid sprocket engine crank nut (right hand thread) clutch hub nut (left hand thread) transmission sprocket nut (left hand thread)
DynaJ
06-01-2016 06:00 PM
BKSinAZ
02-03-2013 06:17 PM
jryder
Panhead
06-24-2010 01:50 AM
FreedomRider
10-19-2008 08:34 AM
56Panhead
07-11-2006 07:34 PM
Quick Reply: front sprocket 1976 super glide
