dry push rod adjustment
I have a question about adjusting the push rods with hydralic lifters.
I rebuilt my 73 shovelhead after cleaning the lifters, i adjusted the pushrods as follows.
got lifters at lowest point adjusted push rods so they just made contact with lifter. backed off 1 3/4 turns.
Now my question is do i adjust them so the small spring on the lifter is collapsed,and the plunger is bottomed right out in the lifter cylinder?
With no oil in them they are almost bottomed out.
The manual says to adjust so plunger is bottomed out,then back off 1 3/4 turns.
as of now they are sloppy.
Do i kick the bike over with the plugs out until they pump up with oil,then readjust?
I just don't want to screw something up at initial startup.
A little help would be appreciated.
Thanks Sneeky
Thanks Sneeky
