question 2: Passenger footpegs
Hi,
Can someone tell me where/ how the passenger footpegs were originally mounted on a 71 FX?
I found some brackets on e bay that look like they could attach to the frame behind the tip of the front exhaust pipe.
I'm trying to find a solution that will keep the little lady from burning her right ankle on the exhaust.........that tends to put her in a bad mood....
Any input would be appreciated!
Mat
Mat
The original ones were mounted to the lower shock stud.
http://images.google.com/imgres?imgu...26tbs%3Disch:1
1973 for sure maybe 72 moved them ahead to brackets on the frame.
There is a verticle two hole block on both sides of the frame just behind the swingarm bolt where the brackets mount and the peg goes on to them.
