I've got a knocking coming from my primary when the bike is in neutral and the clutch is out. It will quit when the rpms are raised or i pull the clutch in. I'm thinking my throw out beariing is the cause but was hoping somebody could save me a bunch of searching.
This is on a 78 FXE. I had to replace the compensator last summer when the weld broke on the old one. The sound popped up now this spring when i was getting it ready for this season.
Could be the clutch hub ,a sure sign is when you try to start it the starter will make a funny noise or the kicker may slip.Not matter what you need to take it apart to fix it.
Flying: When you talk about kicker slipping? You mean it skips when you kick it over or won't hook up?
Charlie Bone: The chain is set right but if it's to tight could this be a cause?
I wouldn't think so, but don't know. Is it set right or too tight? If it was too tight and is still there after setting chain tension correctly, that wouldn't be it.....obviously.
