Super b pop's / thru pipe's ??
Old 03-06-2010 | 08:17 PM
dwm1961's Avatar
dwm1961
6th Gear
Default Super b pop's / thru pipe's ??
I have a 1978 80 inch shovel head ,and i'm runing an S&S Super B and it pop's thru the pipe's while i'm riding ?? some times it double pop's "pop,pop" and other times it just pop's a single time ?? it damm near act's like it cough's ?? any ideas ?? please help !!
thanks
BabyDave
Old 03-06-2010 | 08:21 PM
dwm1961's Avatar
dwm1961
6th Gear
P.S. it's running the stock factory electronic ignition !!
Old 03-08-2010 | 04:00 PM
FLYING's Avatar
FLYING
Sounds to me like a lean pop,are you running drag pipes or some that have very little baffels?
Old 03-08-2010 | 05:01 PM
48pan's Avatar
48pan
Pull your plugs and take a look at them for the color. That should give you an indication. Does it pop at high speed, when you give it the gas, or low speed. Running lean will generally pop thru the carb and rich in the exhaust. You know what S&S stands for, spit and sputter.
Old 03-08-2010 | 07:05 PM
panz4ever's Avatar
panz4ever
All the above you should check plus a leaky manifold. How old are the rubber o-rings?
Old 03-09-2010 | 09:41 AM
dwm1961's Avatar
dwm1961
6th Gear
Default pop and pop sum more
Thanks guy's : I'm thinking about the "O" rings my self ,the plugs are BLACK, so it's looking like it's running Rich ?? what i'm thinking is just redo the carb and O rings ,adjust the timing and check the valve adjustment and then see where i'm at ,and at that point i'd know what i have there at least !! ??
and then we'll see what we see ??
BabyDave
P.S. had a great time at BikeWeek, But the weather SUCKED !!!
Old 03-11-2010 | 06:25 AM
09DynaMan's Avatar
09DynaMan
or lean, and burning oil
fadenfast
Exhaust System Topics
11-06-2017 12:57 PM
R.N.CUMMINS
EVO
03-25-2017 02:21 PM
mitchxc700
Carburetor Related
07-09-2013 05:33 PM
solitaryman54
Ironhead
12-11-2007 09:20 PM
sickshovel
Shovelhead
06-16-2006 11:01 AM
