Shovel Top End
Shovel Top End
I'm needing some advice, Picked up a set of 74" jugs and heads, jugs are scored pretty good and heads need valve job. I'd like to give the engine a bit more oomph. what type of pistons should I run, flat top high comp?? and should I have the jugs bored before ordering pistons (sizing) that makes sense to me, although I have no brain sometimes. As for the heads, what can you recommend for a complete valve job, types etc.... and i've heard of a five angle valve job, what the hell does that mean??
thanx for the input
Jeff
Note : i'm in Florida and it does get warm, if that matters
thanx for the input
Jeff
I like KB pistons(great product for the price), but you run them at half the clearance of standard pistons so make sure whoever is boring them knows that. clearance is .0015" instead of .003". they make them in 9.5:1 compression, your machinist should be able to tell you exactly how much oversize pistons to buy, so have him look/bore the cyls before you buy pistons. He can then finish hone them to proper clearance once you get the pistons.
as for the heads, rowe makes good reliable valves and guides. and a standard 3 angle valve job is fine for a shovel. I would replace all valves and guides, as long as you are there.
I have been running this setup in my 1980 FXEF with an andrews a/b grind cam, and it has been very reliable and the power is pretty good as well. I live in Dallas, where temps hit 90-100 4-6 months out of the year. (oil cooler is a life saver here!)
In my shovelhead days, it was common for us to install bronze intake valve guides with valve stem seals installed. Cast iron exhaust valve guides without valve guide seals. The thinking was because of exhaust valves getting so hot, it was a good idea for a little oil to be lubricating the valve stem.
Very much agree, if horsepower is your goal a good set of ported heads will definately benefit the shovel head motor.
run the valve seals(cast or bronze),go with about 10.0-1,on the shovels,we use andrews #6 cam,dual plug the heads.as far as porting goes,with the inconcistency of machining,we have to see the shovel heads first before we will do any porting(some heads its not cost effective,cheaper to get aftermarket heads)
kirby
facebook: kirby apathy
kirby
kirby
kirby
