Spark plugs keep going bad
Thanks Filthy and Steve for your responses. Sorry I didn't get back to answer sooner as I was driving up from L.A. to San Fran and submitted this b4 I left.
I've attached a jpeg of the plugs. The plug on the left is the rear cylinder and the plug on the right is front. The front (right plug) is a little oily and the rear (left) dry but a little fouled.
Hope this helps you help me.
Thanks again
Thanks again
They look fuel fouled. What carb are you running. Answer the following questions for us and we will probably be able to help.......
Have you recently done any jetting work on it?
Is your bike starting easy and running good.
Is your battery/ignition in good shape.
