How much oil, and what weight
another question, there are no drain screws in the bottom of the fork tubes. or maybe do i have to take the front wheel off and they are
under the botton of the tube. my 06 has them on the backside of the tubes. so i figure these must be directly on the bottom. is this correct
thanks again
thanks again
other than taking the tire off i cant find a plug or screw or anything that would
lead me to drain the fork on either side. the forks are chrome and there is a flat
place on the backside of the fork where it should be but its never been drilled and tapped and thats it. the place im speeking of it right where my road king has a screw and copper washer. surely i want have to take the bottom slider off to change the oil
would i.
would i.
Maybe this is where the motor co. decided to to cut costs Eliminate the front fork drain plugs ! I do remember seeing an article from either HD or some aftermarket manuf about eliminating the drain plugs The sales pitch was " No more messy drain plugs on the bottom sliders " Ya right ! how messy where they verses changing the fork oil in 20 minutes ! I'm going for another 12 pack !!
scopiques
06-12-2011 12:03 PM
