carb issues
carb issues
I have a '68 xlch and I want to upgrade the carb. It has a Keihin carb right now. I can't get it to stop flooding. I have replaced the float needle but cant find a replacement seat. I have heard this is one of the hardest starting bikes I figure I would be better off upgrading. The engine is a 1200 so I'm looking toward a 42mm but it has to be able to clear the magneto. Any suggestions?
another thing i've done is to take an all metal needle, I happen to have one from briggs carb rebuild kit that i didn't need, and glue it to something you can put in a drill. Put a little toothpaste on the tip of the needle, and spin it in the seat with VERY light pressure, just enough to shine up the seating surface. Just make sure to clean out the toothpaste or whatever you happen to put in there. PS, this only works on brass seats, not viton seats.
Go on shovelhead.us and head to the forum and find Doc , have him set you up with a CV carb ...... easpecially with a kicker!! MUCH easier to start & the guy KNOWS IT ALL when it comes to setting a bike& carbs!
DWIGHT!! I used to live in Chenoa , the little farm house close to the southbound ramps!
