Any Thought on Pushrod Cover Gaskets
Does anyone have any feadback on the different materials used to manufacture pushrod cover gaskets. The old cork style seem to get hard after about a season. I installed these NEW IMPROVED SILLI-CONE things and I think the cork might have leaked less when hard. I guess the gaskets are also made in rubber, haven`t tried those. Anyone have a preference. Also I use Shell-Aero Oil in my shovel, low ash content keeps inside motor clean. But it ain`t cheap, so would like to stop as many leaks as possible.
Stop leaks, it`s a (AMF)Shovelhead. Thanks, Daryl
Received 1,297 Likes
RE: Any Thought on Pushrod Cover Gaskets
I tried all different kinds and always seemed to end up back with the cork ones.
Using that Shell Aero ain't a good idea. Aviation oil has zero detergents, but instead has AD (Ashless Dispersants) additives. Aviation oil is also missing a lot of other additives that your oil oughtta have. It has a minimum of one antiwear additive, about 900 ppm of phosphorus, and that is it. Most motorcycles will have a combination of phosphorus, zinc, and molybdenum as an antiwear package. Airplane oil doesn't have these extra additives because spark plug fouling is a slightly greater problem at 10,000 feet than it is on the ground.
Thanks for the input, haven`t even considered O-ring style, I`ll have to check them out. Sound like I`ll end up just putting cork back in and changing them each season. (man I`m cheap).
Skip, thanks for the heads up on the Aero/Oil, an old friend of mine suggested it. Must just be waiting for us to be puttin` down the road about 70, the motor would seize up and Dean would be there laughin` his behind off. I`ll just bit the bullet, take a second out on the house and purchase a case of HD 30. Just what I`ve been puttin into the motor until about 6 months ago (got my advise). Man, with the price of oil products I`ve had to take all my unused stuff and put it in the gun safe and the guns are stashed all over the garage.
Thanks Again, I always thought chrome was just a way for metal to look Prudy?
Daryl
Daryl
On my 78 Stroker, I just replace them every year as part of my prep from sitting for the winter. I have solid pushrods so it's easier to pull the rods. Cork work fine, but I have also used the blue silicone ones. Not too much difference. I think because I have the longer tubes for the stroker, they seem to weap more. I've tried everything including custom pushrod tubes. I've just come to terms with the fact that they weap.
1978 1/2 FHL 93" Stroker
2001 Suzuki Hayabusa
2006 FLHXi Street Glide
