Runaway Starter!
Old 04-02-2014, 11:28 AM
GordFXE80's Avatar
GordFXE80
GordFXE80 is offline
Had that happen once a couple of years ago when my starter bolts came loose from the inner primary, luckily I gave the solenoid a few whacks with my leathermans and it did disengage, - good thing it did, but my 80 FXEF also has kick start, no problem getting home and fix the problem. I do have a battery disconnect switch for my ground wire and will get around to installing it asap but also like the extra solenoid Idea, learn something new every day.
  #62
Old 09-07-2017, 06:43 PM
The old guy's Avatar
The old guy
The old guy is offline
If the timing is off where the piston wants to fire backwards --the contacts in the solenoid will weld togeather
metalfarm
21
06-01-2016 07:30 PM
watindes
EVO
09-29-2013 10:48 AM
andyp
05-20-2012 02:24 PM
pjb
EVO
05-08-2012 07:15 AM
jason8251
Electrical/Lighting/Alarm
07-27-2011 03:23 PM
Quick Reply: Runaway Starter!
