Avon Gangster MT90H16 71H
I have a Avon Gangster MT90H16 71H whitewall front tire and I want to buy the same tire for the rear. Problem is, I can only find a Avon Gangster MT90H16 74H. What is the difference between the two tires, and is it ok to use a 71H on the front and a 74H on the back?
My bike was fitted with Avon Venom whitewalls when I got it and both are labeled as MT90 B16 74H but they are also labeled as Front or Back so although the labeled number is the same there is a difference between front and back.
From what I can see from a quick look the main difference is that there is a center groove on the front tire but no center groove on the back.
Not sure what the difference id for the 71H.
Hope this helps.
Mark.
Hope this helps.
Mark.
well, I haven't heard back from Avon yet. But I did go ahead and order one of these
http://stores.channeladvisor.com/deb...20%26%20Custom
hopefully I won't have any problems. From what I can gather, the 71 or 74 is the weight capacity and the H is the speed rating. So using a 71H and a 74H together SHOULD be ok unless I surpass the 71 in weight. I weigh in at about 228, so hopefully I'm ok, hehe. I'll have to lay off the Mexican food maybe.
71, 71h, 74h, avon, difference, gangster, mt9016, mt901674h, mt90b16, mt90b1671h, mt90h16, shovenhead, tires, uk, whitewall
