Gas cap help....
Gas cap help....
I have a 74 superglide with fatbob tanks.I just put the tanks on after repainting.I also put new gas caps.
Is there a way to tell if the vented cap is working properly?? When I take off the cap (either one) you can hear the air escaping,sometimes rather quickly.Is that normal or do I have a faulty vent cap?
I would try my old cap.....but I think I threw it away...live n learn....
Thanks in advance for any help
I did check the right side cap.It is the vented style.It has what appears to be a blue "valve" in the middle of the bottom side of the cap.
I didn't know if there was/is a way to check the cap to see if it is working properly.I took it off and messed with it a lil and put it back on.Seems to work fine...for now.But,I haven't ran the bike any either.
Thanks for the response.
I'm thinking that valve on the cap is just to let air in as fuel is used but it doesn't allow the tank to vent to atmosphere. I would not want pressure building up in my gas tank(s) because of engine heat or the sun shining on the tank. Myself, I'd look for a cap that just has a vent hole, not a check valve. Maybe you could just pull that check valve stuff out of the cap...
Hope you get it resolved.
