good aftermarket FLH shop manual?
my original shop manual doesn't have a good diagram for all the inner primary gaskets and seals. \\; Is there a diagram somewhere I can see exactly which seals go where? \\; Is there a more comprehensive manual out there that is better than the original?
RE: good aftermarket FLH shop manual?
The parts manual for your model and year should show an exploded drawing of the primary with the seals and gaskets. \\; \\; Here is a page from a 1971 parts manual.
[IMG]local://upfiles/65828/61A6111C13A24C0EB3E0475DBBD7EAAD.jpg[/IMG]
I have a 1959-1969 AMF Electra-Glide service manual and it has no exploded view of the primary chain housing. \\; Thanks for that exploded view. \\; My inner primary ('66) \\;is not one of the two in the diagram. \\;
From what I understand, the '66-'69 were called \\;"generator bottom" Shovelheads. \\; Would really like to find a diagram somewhere so I can find the right hardware and gaskets that I'll need.
What I really need to know now is what spacers and/or seals I'll need that go behind the engine sprocket \\;since \\;I will be running a belt drive. \\; I'll want to be extra sure that the spacing is correct between the engine sprocket and crankshaft spacers.
Ok I'm going to try to attach the page from the 58 to 68 parts manual. \\; Shows your cover but not whats behind. \\; \\; The oil seal i believe is built into the threaded insert called nut, sprocket shaft bearing 34031-55, inserted into this is a spacer of variable thickness, depending on your requirements. \\; According to service bulletin 552 the old two piece spacer was replaced by a one piece in 1967 and the old spacers where no longer available. \\; PM me your email address and I will send you the service bulletin.
[IMG]local://upfiles/65828/D24CEE54EF514FBAB72C072BC48D6EFA.jpg[/IMG]
ddj94kw
06-17-2008 09:00 PM
