going thru coils
going thru coils
 \\;Hello every one, \\; I did \\;a top end job on my shovelhead this winter, new clutch, \\;front end, paint and about a million bucks with of chrome. Got about 300 miles on break in. After a short run and it sits I go to fire it up and it wants to run on one cylinder. I can replace the coil and it seems OK again. I have gone thru two coils so far. Has someone delt with this and solved the problem. Please whats the fix? \\; \\; \\; \\;
RE: going thru coils
redtruck, I cannot think of any way a coil will fail (barring extreme vibration or heat) unless it is defective. I suppose it would if it was used in a totally wrong application with extreme voltage or current put through it but otherwise all I can think is, it is defective. I had a coil from Daytona Twin Tech fail on me that I believe took out my ignition module but I do not see it the other way around.
Can you return at least one of them as a defective? If you can do a return, try to get a brand name one (if you have not been using a brand name) and pay the additional balance, if any.
What kind of ignition system are you using, electronic or points?
Seanrlynchh
04-13-2013 06:15 PM
