S&S Carb Help!
S&S Carb Help!
Hello,
I've just rebuilt my S&S carb per specs and now have it mounted on the manifold with the throttle cable attached. Possible issue: Is the butterfly when the throttle cable disengaged supposed to be closed flush with the venturi hole or carb body hole? Even with the throttle cable removed, it doesn't seem to want to close shut. I need some good advice here. Thanks.
RE: S&S Carb Help!
The throttle plate has an angled grind that allows it to be installed PROPERLY only in one position.
Check it carefully to ensure you have it properly installed. You will be able to tighten it in the incorrect position so look closely for the bevel.
[IMG]local://upfiles/56014/2CB4972AB670434BB6974579BC4BEED9.jpg[/IMG]
[IMG]local://upfiles/56014/2F213C3A71C94B4C9015A8799275700B.jpg[/IMG]
armondojab@gmail.com (05-12-2023)
