lowering and the kickstand.....
RE: lowering and the kickstand.....
Here's my .02 cents. Dont cut your existing kick stand. J&P Cycles and Dennis Kirk both have kick stands for lowered bikes. If you cut yours, you may find it difficult to kick it back out with your heel while on the bike.
Like I said, just my opinion..........
what happens when you heat it is the not only does it weaken the kickstand and ruin the finish but it also changes where it lands when you put it up. anything radical will hit in the wrong spot.
the wedge is the safest and most ecinomicall bet for your situation. you would have the thicker portion at the top of the ks bracket this way the bike can lean over more.
also IMHO if you have or use a kicker DO NOT heat the jiffy stand.
ORIGINAL: lowlife 801
thanks guys. i'll probably heat it. if i don't like the result i'll buy a new one.
Received 1,296 Likes
Never had a problem with the heating process as far as strength, and these were all on kick-only bikes. As far as the hitting the wrong spot deal, that's where a little common sense comes into play. If the angle would cause it to hit where it oughtn't, then you do another route.
Ran a OEM kickstand for 20+ years after heating and bending it after stretching the frame.
Never had a problem and was kick only for most of that time.
At the time never new a wedge was an option or would have probably done that... Naa probably not, that would have taken to long.. I was much more impatient back then.
I then welded a loop on the end and adjusted to be able to hook it with my heal. Worked so well had it re chromed[8D].
94nostalgia151
01-25-2010 08:04 PM
