Increasing rake
Increasing rake
Ok guys on to the next project! Thinking of increasing the rake on my ride. Right now it has a springer front end. Other than cutting the neck and re-welding....What, if any, are my other options?
[IMG]local://upfiles/42314/E411CB9D9FAB47C884A3397107DC1580.jpg[/IMG]
[IMG]local://upfiles/42314/ADFADEF58004415199D6A30AF49BBA40.jpg[/IMG]
RE: Increasing rake
ORIGINAL: ACHALLIE
I am glad to see your not raking a tree ? that’s the cheap way, but not too cool, what I mean by not too cool is dangerous !
Way back people done it, wasn’t to smart then not now either, before anybody spends money in a raked tree, instead of the right way "rake the neck of the frame" go to the link.
BTW- one won’t find better front ends than from Custom Cycle Engineering of CA
cj
Some reasons better laid out on raking, check it out.
Good luck, your doing it the right way !!!!
[IMG]local://upfiles/16813/2FD27BD1107244D39470AA1F11C7AF81.jpg[/IMG]
RE: Increasing rake
ACHALLE,
The "blue-wrench" option is permenant! Or in words appros to the season, You can not un-butcher a frame.
May i suggest that you explore the option of a custom frame. [They] are to be had in a large array of choises; from: stock with 10deg. rake, stock with 10 deg. rake and stretch, rigid wild and upand at prices that won't take food from the hound-dog's mouth. Try Fog Hollow, last time i checked they had a good selection at reasonable coin.
If you cut'er neck and after a time, don't like it, your options are about the same anyway. And if you do like it then you've the frame-work (so to speak) for the next project and thereby stay looped into the perpetual Ride, Dream, Build continuum.
Skip, A&P, Caretaker of the last production Shovelhead
P.S. (to hotrod351) We saw a guy do just that in about 1979 and the Harley Spirits were so pissed-off they jammed his *** (with bike attached) under 18 wheels. His grieving relations blamed alcohol, but we knew better.
RE: Increasing rake
If you're not looking for any radical change, you might want to check out an adjustable rake triple tree (wideglide), which came stock on some olderDuo Glides for when you attach a sidecar. J&P Cycles carries these triple treesin their vintage catalog(part # 231-015) for about $500.
I had a '71 swingarm (with an older generator shovel motor)that had a2" over stock fork with thissetup, whichgave a fairly decent rake. Cutting and welding frames can get somewhattricky (and dicey)unless you, or can find someone who, really know what you're/they're doing, and have the rightequipment to do it with. Not to say that you can't or don't. If you do and have, all the power to ya!
[IMG]local://upfiles/41673/40C0B29937344B8E96DF78621FC57856.jpg[/IMG]
RE: Increasing rake
There are a number of factors involved in raking the front end.
If you rake the neck more than a couple degrees your stock springer will not be long enough and the frame will set on the ground.
If you get forks long enough for ground clearance(WG?) you will be increasing the trail, making the front end flop to 1 side or the other and steer very heavy at slow speeds.
A combination of raked neck, longer forks and raked triple trees can restore a reasonalble trail and make for a rideable bike similar to stock. Extended springer with extended rockers will do the same thing (Sugar Bear builds some extreme springers with this feature)
At any rate, do your homework, work out your geometry and find a great welder with a frame table and you'll do OK. Do it half *** and you will probably regret it, even fatally!
PS Trail is the distance from the center of the tire patch to the point directly in line with the centerline of the neck where it hits the surface of the road(floor). 4-6" is considered normal.
