Help! driveability problem
Ok guys...need some help. '79 FLH. Having a drivability problem. Recent work includes new cam, s&s super e rejeted and adjusted, intake "boot" replaced, new plugs. Recently purchased this bike but was told that the ignition circuit is new.
After (and before) I got it out of the shop I have experienced a problem with the motor surging. When I got it out of the shop it ran fine for a few miles then began surging again. It surges to the point that it finally dies. I plan on replacing the fuel filter this afternoon but was wondering if there are any other ideas out there.
RE: Help! driveability problem
Sounds to me like it could be running too lean. Possiblythe fuel level in the carb getting low (fuel filter or fuel cap not venting), intake air leak, carb jetting is too lean.
Does it start surging right away at a certain throttle setting/RPM, or does it seem tobuild up to doing it, gradually gettting worsewhile running? If you coast for an amount of time, once it starts surging, and get back on the throttle does it seem better, or the same? If better, I'd suspect a fuel supply problem to the carb.
How much throttle when it starts surging? If it'smid rpm's, and little throttle when surging I'dmake sure the intermediate jet isn't too lean.
Also, I'd check the intake manifold seals with WD40 while running to make sure they're not leaking. Does the carb have asolid mount to engine besides manifold? It's not vibrating to much causing an intermittant air leak?
Good luck with it!
Jeff
Good luck with it!
Jeff
diddlyd
Carburetor Related
12-19-2015 11:17 PM
jaystay42
Exhaust System Topics
08-06-2011 08:10 PM
