Points headache is solved
That's what the problem was. I could advance the flyweights but the bolt was still tight enough to keep it from moving a whole lot. I moved just a little and I kept running into the light coming on at the wrong time and screwing up the proper time frame of when the light was supposed to be coming on I fought with it for a couple or hours because the light was coming on at a different time. The bolt was just tight enough that the weights went around but slipped a little each time.
