1972 FL Frame Tab Identification
Old Yesterday, 05:44 PM
FX Man's Avatar
FX Man
FX Man is offline
Default 1972 FL Frame Tab Identification
Hello all,
Im curious to know if this frame tab on my 1972 FL, is it factory or not? If factory, what does it mount? Thanks
Old Yesterday, 07:35 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,610 Likes on 985 Posts
Brake light tee and switch on mine. But stock it would have been mounted to the transmission plate.
Old Yesterday, 08:57 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,425 Likes on 1,734 Posts
On the very early bikes
certainly my 68
I recall a passenger peg mount there
dont temember ever using that tab on an FX
but, tabs are there thru late '70's anyway
Old Today, 05:33 AM
hellonewman's Avatar
hellonewman
hellonewman is offline
Received 6,528 Likes on 2,719 Posts
My 71 and 72 FX both have that bracket. The mid control peg mount attaches to the transmission cover studs and that vertical bracket.
Old Today, 07:05 AM
Architect's Avatar
Architect
Architect is offline
Received 5,463 Likes on 2,783 Posts
I thought the FL's used it for the rear exhaust support?
Old Today, 08:26 AM
pgreer's Avatar
pgreer
pgreer is online now
Received 1,656 Likes on 1,061 Posts
My 1976 FX and FLH both have that bracket / tab. I don't think the FLH uses it, but on the FX the rear brake light switch attaches to it.
The FLH has a pressure based switch that is in a tee bolted to the trans plate. The FX(E) has an electrical switch that is mechanically actuated (via a link to the pedal) when the brake pedal is pushed.
I had to look to find a picture that shows the forward controls and brake light switch on the FX model. Look for the red circle and arrow showing the switch location.
Paul
Old Today, 09:05 AM
hellonewman
The upper large hole is for the exhaust , FL I assume and the FX uses only the smaller lower hole for the mid control mount. Dual purpose tab.
Old Today, 10:02 AM
Architect's Avatar
Architect
My 1970 FL only has the upper hole, no lower hole.
I agree the support plate for the passenger buddy peg may also use that bracket.
FX Man
Shovelhead
05-13-2022 06:58 PM
Night_Train
Shovelhead
05-17-2014 12:56 AM
PurpleBook
Shovelhead
06-16-2013 05:33 AM
Rebelsonsmc
Classic
02-18-2011 05:46 AM
cbydve
10-21-2010 05:11 PM
Quick Reply: 1972 FL Frame Tab Identification
