In need of assistance
Yeah I'm in no rush, just want to get it right and enjoy the process. I'm shooting for next spring hopefully though. At least I'm halfway done by having everything stripped and cleaned now. Just have to inspect and refurbish what I can and do it one piece at a time if I have to.
Spanners39 (07-02-2024)
Dmullins306 (07-02-2024)
Dmullins306 (07-03-2024)
So it was suggested to me by the machinist that since I was using bigger pistons and the 80 jugs, that I should use the spacers at the base nuts that the 1340s use. My dad just had the regular washers there to begin with. Now as I'm putting the cylinders on, I don't have the clearance on the stud to be comfortable. Do you guys think I need the spacers or would I be safe using the washers?
You need a full nut of threads or something is likely to give (threads), so I'd ditch those and use lock washers. The ones you have were used on later model Shovels anyway, the earlier ones used lock washers.
The first time I had a frame powder coated I was not happy with the results. The problem is the powder coaters tend to put the powder on much thicker than paint. When they do that, it usually fills in the stamped VIN on the frame neck and other frame markings than matter to some people. Which may not be a big deal in some states, but when comes to state inspections it can be a problem. So I asked the powder coaters to skip the VIN pad and then simply paint it with some enamel and blend in the edges. And, you will need to show them as well as mark every hole you don't wan't powder in or they will fill in some things that shouldn't be. When you get the frame back, you will need chase all the threads before you start to reassemble anything.
Most likely I'd look for a set of cad plated Grade 8 nuts rather than chrome ones (which will rust).
Be sure to include the swingarm, battery box, oil tank, clutch cable bracket and rear brake caliper bracket with the powder coating.
Paul
Paul
Dmullins306 (07-08-2024)
