72-81 front master cylinder size?
does anyone know what the piston diameter is on these stock master cylinders?
i have the traditional stock style hand controls on my 67 that i want to get rid of.
i have dual jaybrake 4piston front calipers, they work fine right now so i want to make sure the new master cylinder i get is the same size
ive searched google and part numbers without any luck. thanks in advance
The following 2 users liked this post by johnjzjz:
NO_SPRK (03-18-2023),
Uncle Larry (03-18-2023)
Ran dual piston dual calipers with the stock old style shovel MC before, while it works the level travels a lot more and you just know there's more there than you are getting. I currently run dual 4 piston Wilwood calipers with the 82 and later style 3/4" bore MC, bike damned near do a stoppie if you grab to hard a handful now.
Not a big JayBrake fan anymore. While they were the **** back in the day current cheaper alternatives are much better calipers performance wise. This is my rear setup, the pads alone will run $90 to replace come, only did this because a supplier I was using gave these to me to $50 each new and I was bored one winter.
i dont think theres anyone to call now. last i read supertrapp bought them in 2011 and nothing on their website shows it. i found one old PDF catalog from 2015. i think youre right on the 11/16
Roadkill73
01-19-2014 10:45 PM
