Plastic Breather Gear
rockher_man (03-08-2023)
The plastic is soft and tends to hold on to metal particles and score the breather bore as the breather rotates. And as said above, they will warp out of round which also damages the breather bore.
If the breather bore is still in good condition, replace the breather with a steel one. S&S makes a reed valve breather for EVO engines, but it is not shown as compatible with Shovelhead engines.
Depending on the year Shovel, I'd also check the inner can bearing and replace with the full compliment bearing while in the can chest.
Paul
Paul
The following 3 users liked this post by Joe12RK:
TwiZted Biker (03-08-2023)
